Invert Table axis and save configuration
F1Fever
Post by F1Fever »
Would it be possible to invert the way a table displays and save that configuration?
Say rpm vs map where the y axis is the map and it counts down instead of up?
Also would it be possible to swap the x & y axis and save configuration?
If this exists I'm missing where it's located
nomecone
Re: Invert Table axis and save configuration
Post by nomecone »
I believe it exist in the XDF settings or global setting of the app. I do not think a per parameters reverse order exist. I had a case of a few human readable items being written backwards in the rom. I found the setting and switched it but then every table in the whole XDF was also flipped so I just left it default and lived with it.
Sorry I'm on phone or I would look for where it is in the app. The place not to look is an individual parameter setting as far as I know.
F1Fever
Post by F1Fever »
Thanks for the reply. It would be nice to have that table specific
On the per-table basis, is reversing the order of row/col cells defined in the table (and/or adjusting step) insufficient?
If there's a global setting for this and a per-table setting as you suggest, how should those be combined? If the global setting is set to reverse, and the table is set to reverse, then that table is shown in non-reversed order?
845motorsports
Post by 845motorsports »
I believe he means like Ctrl + t in win ols I could be wrong though!Q=
F1Fever
Post by F1Fever »
Mangus wrote: Thu Aug 01, 2024 8:40 am On the per-table basis, is reversing the order of row/col cells defined in the table (and/or adjusting step) insufficient?
That would be very nice. I have some tables with rpm and others with map on the x axis that are ascending. I would simply like a setting to invert how the x axis is displayed. Since I made this post I have become accustomed to his it's laid out. But if it was a simple change or a setting I was missing I would like to be able to have the rpm descending.
Ie
3
2
1
Vs
1
2
3
