Item Comments bug
Mike Clouser
Item Comments bug
Post by Mike Clouser »
I am using TP version 4.12. Win XP
You may already know this...
After typing in a description in the Edit XDF window and hitting apply, It will only save about 100 characters of it.
Thanks!
-Mike
For an object or the XDF header? I can't reproduce this. Here's what I did (and an example of explicit repro steps, which helps a developer reproduce "bugs" that users find):
1) Load an XDF
2) Select the first item in the constant list and hit F2 to edit it
3) In the description field, type "12345678901234567890" repeatedly to make counting characters easy. Use copy and paste to make this go fast.
4) Enter around 200 characters (or the number of your choosing).
5) Hit apply
6) Save the XDF to file
7) Re-open the XDF
8) Edit the same item
Notice that all characters were persisted and re-loaded.
9) Execute these steps for the XDF header (Ctrl + F2).
So, if you can reproduce this, can you give me more info?
Mike Clouser
I just tested it like you said and I just now realized it only happens in the Functions, the Tables and Constants seem to save it ok.
-Edit- I also just tried it on the XDF Header as you asked, it worked, but It loses the last character unless you add a space behind it ( a bug metioned elsewhere in this Forum).
-Mike
Thanks Mike. I'll take a look at functions. I fixed the XDF header character issue for the next release.
EDIT: Found and fixed the function editor problem. Thanks!
