Can someone please help me on setting up the right data in TunerPro. I have managed to get connection from the OBD contact to the computer and I’m using the AutoProm as a PROM. So both the “DA link connection” and the “Emulating” connection are working just fine. My goal is to set up the data tracing in the “spark advance table”. I have managed to get the data tracing working for the RPM.
In the “spark advance table” there are two types of data. “Y”, I believe is the RPM from the engine. This has a scale from 400 -4800. But what is the “X” colum? This has a scale from 32 to 208. What kind of setting do I need to do so the “black dot” regulate in both in the “Y” row and the “x” colum?
These are the settings that I have done.
1. From the title bar :
a. XDF
b. View/edit XDF header info
c. DA Assoc
d. Selected the right definition file
2. From the parameter tree
a. Tables
b. Spark advance table
c. “F2”
d. Rows
e. Data type = Engine speed
f. Stock units = Revaluations per minute
g. Row label type = Floating point
h. Colum
i. Data type = ???
j. Stock units = ???
k. Row label type = Floating point
l. DA Assoc
m. X axis DA link – Link mode = ???
n. X axis DA link – Link mode = Explicit = Engine speed
3. From the title bar
a. Acquisition
b. Edit definition
c. Values
d. Engine speed
e. Data types = engine spees
f. Stock units = revolutions per minute
g. Air flow
h. Engine speed
i. Data types = ???
4. Title bar enabled
a. Data tracing
b. Acquire data (connection)
c. Data tracing
Are there other settings I need to preform?
Are the settings I have set up right?
What are the right settings on 2.i, 2.j, 2.m 3.i, 3.j and why?
Help would be greatly appreciated…
