Just put a 383 in a 92 Caprice with 16136965 ECM running $62 mask and was wondering how you adjusted the cylinder volume for a 383.
What Scalar to use for cylinder volume?
OK I see that the Base Pulse Constant is where I need to change for engine size and injector flow.
Is there a way to know what the BPC should be with the 383 and stock injectors?
