The definition file I'm using has the following constants:
Speedometer Scalar
Speedometer Scalar, Fraction
Speedometer Scalar, (Scan Tool)
Time Between Pulses For 'Stop'
I think I have a formula for all but the " Speedometer Scalar, (Scan Tool)" worked out. Anyone know what this is used for? From looking at stock bin files it's the same number from 3 cars with the same gear but with different size tires. On the other hand a L99 Caprice has a much lower number than a LT1 Caddy with the same gear ratio. Also F-body bin files have relatively higher numbers.
Jim
P.S. The LT1 and PCM now reside in a '91 Camaro.
