bitwise AND not working on 32bit cells
updatelee
Post by updatelee »
X & 0xFFFFFF0F
works on 8 and 16 but if I select 32bit it just messes up
updatelee
Re: bitwise AND not working on 32bit cells
Post by updatelee »
I should provide more info lol
conversion when set to just X
8it = 86
16bit = C386
32bit = 82D5C386
when conversion formula set to X & 0xFFFFFF0F
8it = 06
16bit = C306
32bit = FFFFFFFF
the bitwise AND operation works in 8 and 16bit but not 32bit
Will look into this. Thanks!
Fixed for the next release. In the meantime, for the values you specify, this will work if you turn it into a signed value.
updatelee
Post by updatelee »
Yay ! thank you so much !
updatelee
Post by updatelee »
Latest version tested working 100% thank you !!!
Glad to hear it. Thanks for checking.
