Flame tuning 413
Blakearaeman
Flame tuning 413
Post by Blakearaeman »
Hello, my car is a 413 red label e36, I've been self tuning with an emulator and recently had success with a burble tune using this ecu (with help from this forum). My question is, how can I turn my pops and bangs tune into a flames/Gunshot tune?
nomecone
Re: Flame tuning 413
Post by nomecone »
To best define what you are wanting, do you want the flames/gunshot on lift off the throttle decel still?
The real aggressive flames gunshots I have seen are 2 step and or antilag with holding the throttle open.
If it's lift off throttle more aggressive pop and bang you want you have to keep playing with the known decel tables and some timing.
If it's ignition 2step/antilag type... One it's even more dangerous to the engine. Two the easiest way would be a multi tune chips aka "2-timer" or similar. One tune for ignition type antilag tune and the other for normal driving. Controlled by a switch/button. Rewriting the code is the other option. Olafu did some experiments with rewriting code for things but the publicized amount of information is limited.
