Just downloaded and signed up. 1st q. How do I open tuner pro? I tried many programs to no avail?
A pal did a full running tuner download of my 90 zr1 have no way to open that either. He said download tuner pro?
Help? Tkx jim facinelli
Super beginner qs HELP
Re: Super beginner qs HELP
1st, you need TunerPro application, You can get that from the website
and you need a cable to connect your PC to the OBD port on the car.
2nd, You need ADX file (This is the definition file for your car data output)
That's all you need to log data and display what is happening.
To Program or make changes to your car, Add these:
3rd, You need XDF file, (This is the definition of what each location is for programming changes in your car)
4th, The BIN file (Your tune file that the ECM uses to run your car)
Hope that helps
Jp
Hope that helps
Jp
