motronic 1.3 bmw e30
any info. pleace a xdf. file would be nice or if anyone can tell me how to calculate hex to fuel/timing value??????
BMW E30 Motronic 1.3 XDF
Hi Craig
I've been working on an xdf for my beemer for some time but its not complete yet due to the lack of knowledge etc........
I have got part way through it and got it to display many of the various maps & locations within the bin file that I've managed to pick out so far........
AND run it live from my emulator!!!!
......(Pocket Romulator v1)
Haven't realy tried to make any real changes yet as I need an AFR guage to look at the wideband O2 side of it.
Also tried the basic address tracing utility on the emulator software but its not good enough yet.
How far have you gone in-to this subject mate?......
Any others working on this out there?
Regards
StigWelder (Ant)
Regards
StigWelder (Ant)
Hi Rogue.Rogue_Ant wrote:StigWelder,
What car are you working with? What is the processor of the Motronic (Intel 8051/2?)? What size is your binary? How many teeth for the reference sensor? I might be able to help some, as I'm working on the Motronic 3.1...
-Rogue
Im working on my BMW 320I E30 (1990 so its the later 1.3 and not the 1.1)........It has a 36 tooth crank trigger , just like the M50NV early 3.1 system. Bin file size is 32k from the 256k eprom...Not 100% sure on the processor, i'll check and get back to you with an answer.
I made a conversion on the current engine and put a 24v 3.1 system on it (its a 12v engine).............AND it runs fine!!!!!!!!!!......
I get sequential coilpacks and injection + a MAF instead of the old AFM , Dizzy & phased/banked injection.
This puts me in a bit of a delema as I need to work on both systems but have done more with the 1.3 system so far resulting in the creation of a some-what raw xdf file for it using 2 tuned roms as a starting comparison.
Regards
StigWelder
