Why am I having a difficult time finding a MEFI1 Definition file. I have the RamJet tune file already but I need the XDF file for definitions.
MEFIBurn wants $600 to have access for this file. That's total BS.
Does anyone here have the XDF definition file for one the worlds most common ECM's made during mankind??????????????????
MEFI1 Definitions - PLEEEEEASE!!
Jeeps3, I'm new to this MEFI tuning and I just bought the MEFIBurn software. Bob at OBD Dianostics is a great guy and will answer any questions you may have, I spent a day with him and he had my car running better that it's ever run with the generic program that Arizona Speed & Marine had in it.
The Burn software allows you to scan, data log, and change any of the ECU's settings you wish. If you already have a way of programing your ECU and need a startup program I'm sure Bob has one that he'll share with you.
Russ
Russ
67 Corvette EFI MEFI3 ECU, Programed using MEFIBurn
Re: MEFI1 Definitions - PLEEEEEASE!!
Are you trying to tune a Ram Jet engine or are you wanting to modify a Ram Jet tune to work with some other engine? To the best of my knowledge the MEFI1 was not used on any of the GM Ram Jet engines. I have one of the first Ram Jet 350 engines and it used the MEFI3.jepps3 wrote:Why am I having a difficult time finding a MEFI1 Definition file. I have the RamJet tune file already but I need the XDF file for definitions.
The MEFIBurn package includes not only the XDF files for all of the MEFI controllers but also software/hardware that will allow you to transfer your tunes to/from the MEFI controller. The complete MEFIBurn package also includes definition files for TunerPro and ScannerPro. If you check around I think you will find that $600 is relatively cheap for this type of tuning package.
Charles
