There are several 2D tables in a bin file that have non-consecutive addresses.
Explanation - The 2D table references the X-lookup first, then the corresponding calibration value. This pattern repeats itself for the length of the table -lookup, cal, lookup, cal etc.
In order to reference the values, I currently need to treat each X-lookup and cal value as scalars. This works, but is not very convenient. Also doesn't allow for graphing etc.
In any case - it would be great if you could define a step between values in a table. For standard tables, the step would be zero. In my case, I would have to set it to 1 byte. So, it would start at the defining table address, and then skip every other byte.
Maybe there is already a way to do this, but I'm new and couldn't find it.
Or, maybe I'm the only crazy dude that would actually use this feature - and if so feel free to tell me to stuff it
Thanks!
