Data Format
ecuconnection
Data Format
Post by ecuconnection »
Hi all, thanks in advance for the info/help
I have a file that requires 8bit 128 format rather then just 8bit standard format or 8bit 255 format
any formula or way to make this happen in current tuner pro?
Regards|
What is 8 bit 128 format? What is 8 bit 255 format?
TwittyBird
Post by TwittyBird »
i can understand that too.
i've search on the net but i can find a good answer for that.
dfddfd2
Post by dfddfd2 »
If you are referring to signed 8bit integers in the -128 to +127 range, then just specify the value as signed integer by checking "Signed" in the XDF definition editor.
Dave
