93 Corvette DEF/BIN question
Rottie
Post by Rottie »
I'm using EMP-10 to read the current chip in a 93 corvette. It appears to read the chip and verifies the cache is the same as the chip.
Using the DA3.xdf definition file and opening the BIN, it appears there is a problem. No errors, but the injector constant is 241.24, and some of the spark entries are like 211, etc. It almost seems like it's adding 1's sparatically through the entries.
How can I tell if the BIN is bad or the Definition file is not correct for the application?
Thanks in advnace.
Corrupt bin? ZR1 (which doesn't use $DA3, it uses $F0)?
Rottie
Post by Rottie »
I'll attempt to read the chip again tonight then and let you know.
Not a ZR-1. I wish......
The part that got me was I verified the cache after the read matched the chip in EMP-10. (and the car does run with the current chip) Anyone familiar with EMP-10 that may clue me in to what I'm doing wrong then?
Thanks again!
