Conversion between hex and engineering units
Robin Handley
Post by Robin Handley »
Am I right in thinking that v2.01 automatically updates tables in edit mode with the display option that you select via preferences (whereas v2.0 did not)?
Anyhoo, I was editing an ignition advance table in engineering units, and wanted to view it in hex. I went into preferences, selected hex, and the table updated - but not completely correctly (not all cell values were correct). Killing the edit window and re-opening it worked fine.
Keep up the good work,
Robin
P.S. Having been used to the hex/engineering select button in Winbin being out in the open, it's a little frustrating having to go into preferences for it. Maybe I've got in to bad habits, but I do swap between the two quite often. :-)
have you tried right-clicking on the table? =)
Robin Handley
... no I hadn't (but now I have). Apologies if that was in the Help information...
Unfortunately it doesn't seem to work for scalar values.
Robin
yes, it does. right click on the constants editor. same option is there.
