ok am setting up a isuzu g161 with efi useing delco 808 from a holden astra. now what i need to know is can ues this
http://www.moates.net/product_info.php? ... ucts_id=48
to burn the bins to the chips.
i know i can use tuner pro to edit the bins
but can i ues tuner pro to data log
lost need bit of help
- Six_Shooter
Yep, BURN1 is an EEPROM programmer, and is teh hardware used to program the EEPROM, once changes are made using your favorite editor, mine happens to be Tuner Pro.
Tuner Pro RT has datalogging capabilities. I know there is some documentation on the 808 on TGO (www.thirdgen.org), but not sure what files you will need to actually datalog.
