Bin stacking for Prominator
hotrodta57
Post by hotrodta57 »
New to this. Just got my Prominator installed. '88T/A L98 Used the 6E with ARAP. I ordered the 32k setup (saw it recommended in a thread on TGO somewhere). Trying to understand how to stack the bin into the 32k setup. With the Bin size set to 16k, Chip size set to 32k and Block size set to 32k the layout only allows for one location. Do I use a larger chip size or what. Thanks
If the prominator allows two images to be switched between, then set the bank size to 16KB.
