Injector Flow Rate
91DropTopTA
Injector Flow Rate
Post by 91DropTopTA »
This is a pretty simple question, but I wanted to be sure that I'm doing this correctly. To change my injector flow rate I use the + - keys to get the final number I need. In this case the hex goes from 443B with .58 calculated to 01A7 with 24.02 calculate. Am I reading this right? I need an injector flow of 24.
Just set the view mode to calculated, hit 24, and hit save!
What you outline doesn't sound correct. Incrememting 443B one more should result in 443C.
