hardware not found
JOHN QUINTUS
hardware not found
Post by JOHN QUINTUS »
I have purchase moattes "xtreme aldl " cable and box and have gone to
tools/preferences aldl/emulation and selected "test for valid cable using
settings", it returns with --"cable found and functional". but when selecting
the cable icon it says at the bottom "initializing hardware" then "hardware
not found". what am i doing wrong ??? please help
Post by Six_Shooter »
The initialize hardware is for emulators, it does not get used with the ALDL cable.
JOHN QUINTUS
what do i need to scan . I have an 86 vett moattes usb cable and obd1
connector.
You need to load the correct ADS file, then use the aldl connect button in the tool bar (two blue arrows). If I'm not mistaken you will need to set the resitor switch on the cable to 10K for your ECM.
JOHN QUINTUS
thanks for your help!!!. After i changed the tool bar to show the two blue
arrows it all was clear what to do. thanks for all your help.
Schrade
Post by Schrade »
Six_Shooter wrote:The initialize hardware is for emulators, it does not get used with the ALDL cable.
OK - good info on what NOT to do.
Any chance of finding out what TO do?
