Is there anyway to adjust individual cylinder fuel trims? Like to correct split BLM's, or add a little extra fuel to that one cylinder on the drivers side that fires right after the cylinder next to it (and may be fuel-starved)?
The fuel trim adjustment tables I see are:
WOT % change to AFR vs. coolant temp
WOT % change to AFR vs. RPM
the main VE table (of course)
However, these affect overall fuel trim from what I can understand.
When I run $DA2 definition on tunerproRT, heres what I see:
Again, no option for individual fuel trims on both the constants/scalar drop down or table/function drop down.
Any help is appreciated!
