I'm new to TunerPro and I'm trying to read the data from the 8192 data stream. I can connect fine using the 1227165_160.ads file and read the 160 baud data but that file doesn't support the 8192 baud datastream. I've tried the 1227165_6E.ads file, but it doesn't connect. The ECU appears to switch modes (the lights on my serial adapter flash faster).
There doesn't appear to be an ALDL defination file that supports 8192 baud for the $32 mask. I've read 8192 data with a snap on scanner, so I know it should work. Is it just a matter of making my own .ads file for the 1986 prom?
86 Camaro 305 8192 baud possible?
you would need a 87-88 or 89 BIN and then you could read and tune it using the 32B or 6E ADS/ADX and XDFs.
in the DS file for all of these masks, it states that 85 and 86 ECUs can only communicate in 160baud mode. i believe that for 85, but since the 86 is the same ECU through 1989, the only reason i can think of as to why it wouldn't be able to output a 8192 stream is that there is algorithm stating to do so. why GM would do that, i have no clue.
I think its an issue with the .ads file. I can read the 8192 data with a snap on scanner. And the lights on my serial adapter seem to be flashing quite a bit faster when I request 8192 baud. Tuner pro just won't connect.
I'm wondering if just the proper .ads file for a 1986 would do? I could probably log the raw data and figure out what it's sending.
