Newbie questions Tunerpro Rt
omegan
Post by omegan »
Hello.
Has played a bit with Tunerpro/Rt and have a few questions.
Under Aldl value you see all values to the far left divided under different headings tex. general/important,fueltrim/mixture,idle/iac and so on.
This i understand.
If i look under the tab Aldl flags there are three headlines,Important stuff,malfunction word 1 and airmode word with different "answers" to the left. Now to my question:Under malfunctions word 1there are 7 different error codes 12,13,14,15,21,22,23 and next to those on the left it says ok. Since i have no problems i guess it means everything is ok. If there were problems is this where i see it.For example fail instead of ok? And is it just these 7 error codes i can see.
//Omegan
Post by Six_Shooter »
It would depend on how the ADS/ADX was set-up by the author. There is plenty of room for personalization, and some people will set things up a little differently than others would.
It would help to post which ADS/ADX you are using to better verify what you are asking.
