If I understand correctly from reading posts, you cannot create a xdf from a bin. so my question is will intended xdf files posted work with all bins already in use or are they propietory to the software being used?
I have a chip already installed and I am questioning rather or not the bin and the xdf are matching, should I be worried about this or not?
Also I tried to save the bin file from the chip that is in the car now to the buffer and reburned it onto a new chip and the car will not run as it did with the original chip. Why is that if it is the same bin on the new chip? am I missing a step maybe? I also noticed that ses light is on and the radiator fan is running when I turn the key on or when the engine is running.
I also was reading another post that said you get a manual with tunerpro, Where is it? I did not receive one.
Thanks in advance for your replys
I think I'm starting to get the hang of it, maybe
- Six_Shooter
Re: I think I'm starting to get the hang of it, maybe
You should only worry about the bin and xdf match when you are modifying the bin.carcaper wrote:If I understand correctly from reading posts, you cannot create a xdf from a bin. so my question is will intended xdf files posted work with all bins already in use or are they propietory to the software being used?
Sounds like you need to offset the bin on the chip, so that the bin is at "the end" of the EPROM. GM application?Also I tried to save the bin file from the chip that is in the car now to the buffer and reburned it onto a new chip and the car will not run as it did with the original chip. Why is that if it is the same bin on the new chip? am I missing a step maybe? I also noticed that ses light is on and the radiator fan is running when I turn the key on or when the engine is running.
http://support.moates.net/2010/04/05/pr ... g-offsets/
There is no paper manual, but there is the help files contained with Tuner pro itself, found under the HELP menu found in the main tool bar.I also was reading another post that said you get a manual with tunerpro, Where is it? I did not receive one.
My point was I would like to modify the bin so I guess i do need worry about the match in my case, so how do i modify the bin if the xdf doesn't match, How would I create an xdf file to match the bin ? Is this called a hack?Six_Shooter wrote:You should only worry about the bin and xdf match when you are modifying the bin.carcaper wrote:If I understand correctly from reading posts, you cannot create a xdf from a bin. so my question is will intended xdf files posted work with all bins already in use or are they propietory to the software being used?
I have a chip already installed and I am questioning rather or not the bin and the xdf are matching, should I be worried about this or not?The xdf has absolutly no effect on how the car runs. The XDF is only used by Tuner Pro, to translate the bin into real world, and easily understood units and tables for us to modify the bins.
The problems I'm having with the current program is the idle is to slow, the idle is rolling, the fuel mixture is running lean from low to mid range, other wise top end is fair. The current chip that is installed is unknown but is using a moates.net adapter zif socket type. I'm not even sure if I am reading the chip bin or not. I hope that I can just save the current bin to my pc, edit it with tunerpro and reburn it or emulate it to see what the results are. Am i on the right page?
- Six_Shooter
ok since your interested, As far as the moates equipment I have an aprom which craig moates suggested I needed to tune this 1993 camaro z28 lt1 350 with alum cyl heads, comp cam .534 intake lift, 540 exh lift, 283 int duration, 293 exh duration, 114 lobe separation, headers, nitrous, automatic trans, ecm #16159278. The ecm has a moates g1 chip adapter with a D27C256AD chip installed. I have no idea what brand the chip is, who burnt it or if I can even read it correctly. How can I tell if I can read the bin with tunerpro? I now realize I need a xdf to materialize the bin. I did use the da3.xdf that mark suggested and it seems somewhat there but now I don't know what to do since these questions arise. I can say I could really get into this challenge, it is really interesting.Six_Shooter wrote:Yes, then you need to worry about the XDF...
It would be MUCH easier to point you in the right direction if you listed your exact application.
Yes, a "hack" or "dissassembly" document is used to create an XDF.
Oh and I forgot to ad that it has larger fuel injectors that are excessivly rich using the stock calibration which tells me they have backed the pulse width way down or should I say back out the fuel delivery in the VE table. I guess I will eventually learn the right lingo as time goes on, hope this helps.carcaper wrote:ok since your interested, As far as the moates equipment I have an aprom which craig moates suggested I needed to tune this 1993 camaro z28 lt1 350 with alum cyl heads, comp cam .534 intake lift, 540 exh lift, 283 int duration, 293 exh duration, 114 lobe separation, headers, nitrous, automatic trans, ecm #16159278. The ecm has a moates g1 chip adapter with a D27C256AD chip installed. I have no idea what brand the chip is, who burnt it or if I can even read it correctly. How can I tell if I can read the bin with tunerpro? I now realize I need a xdf to materialize the bin. I did use the da3.xdf that mark suggested and it seems somewhat there but now I don't know what to do since these questions arise. I can say I could really get into this challenge, it is really interesting.Six_Shooter wrote:Yes, then you need to worry about the XDF...
ok where did everybody gocarcaper wrote:Oh and I forgot to ad that it has larger fuel injectors that are excessivly rich using the stock calibration which tells me they have backed the pulse width way down or should I say back out the fuel delivery in the VE table. I guess I will eventually learn the right lingo as time goes on, hope this helps.carcaper wrote:ok since your interested, As far as the moates equipment I have an aprom which craig moates suggested I needed to tune this 1993 camaro z28 lt1 350 with alum cyl heads, comp cam .534 intake lift, 540 exh lift, 283 int duration, 293 exh duration, 114 lobe separation, headers, nitrous, automatic trans, ecm #16159278. The ecm has a moates g1 chip adapter with a D27C256AD chip installed. I have no idea what brand the chip is, who burnt it or if I can even read it correctly. How can I tell if I can read the bin with tunerpro? I now realize I need a xdf to materialize the bin. I did use the da3.xdf that mark suggested and it seems somewhat there but now I don't know what to do since these questions arise. I can say I could really get into this challenge, it is really interesting.Six_Shooter wrote:Yes, then you need to worry about the XDF...
