Hi,
Need some help to get the conversion right for a scanned value in my .adx.
AA) When I ask the ECU for the TPS value the ECU answer back with a 8 bit value = X. (0<= X <= 255)
The conversion of the value should be
for X < 171
TPS = X*0.1848-1.41
and for X > 170
TPS = X*0.7058-90
How should I implement the conversion ?
BB) When I ask the ECU for the injector duration i have to ask two questions.
Question A for the MSB part of the value and
Question B for the LSB part of the value.
The conversion is then 16bit value * 2 for the injector duration.
I tried with
answer A * 256
(Answer B + (linked value from answer A))*2
But it gives me some lag.
Is there any other way to do the converison ?
/Hnerik
Help with conversion of scanned value in .adx
Tried a couple of different things.
For AA) I used a lockuptable. Worked since it was two linear funtions.
For BB) I made another value for the MSB part that I linked to the value for the LSB.
Tried to make a value with an output of 1 or 0 as integer.
And used it linked in another value.
But that did not work because in the other value the linked value were used as floating. 1,12 instead of 1 and 0,85 instead of 0.
Do not know why ?!
/Henrik
Do not know why ?!
/Henrik
