problems with playing back Wideband readings
Mark. B
Post by Mark. B »
Hi everyone.
I have been running my WB afr readings through my autoprom on Tunerpro v5 for a while now.
Not sure if anyone has had the same problem as I am.... My afr comes up fine during regular logging sessions, my issue is during playback, the AFR value is stuck on 1-2 numbers. It seems i get an improper recording, i even looked at the datalog on Excel, and same thing, no recording.
my Ecm is a 165. is it even possible to record with this ecm through the autoprom, or is it my ADX settings?
I find it strange that i get a proper reading, but no recording/playback.
thx
Two questions:
1) Are you running the latest build of v5?
2) Are you running 1227165_6E.adx? If not, you should. If your mask is $32 ('86 TPI), then convert to $6E by unplugging your cold start injector and selecting and uploading a relevant $6E bin.
Then try again and let me know.
-Mark
Mark. B
Post by Mark. B »
Hi,
Yes, running latest software,1227165_6E.adx, and 6e mask.
mark
Mark. B
Post by Mark. B »
Update:
I got it to work now, I went back to running the WB through port d8 on the ecm and using a different adx and bin file, I am able to log, record, and playback my WB perfectly now.
Wish I was able to find the issue with the autoprom methid, just for others interested in the same thing.
thx
