Getting TunerPro V5 set up
airboss32
Post by airboss32 »
Hey folks........after using TunerPro RT V4 for several years, I guess I'm spoiled.
I finally made the switch to V5, but am having alot of difficulty getting it setup.
I'm running a 1993 Chevrolet K1500 with a 16168625 PCM using $0D code. I found the correct files and can get the program to connect to the PCM, but I can't seem to figure out how to set things up to where when I record then read the logs, I can look at the histogram and watch my BLM's and INT changes so I can adjust my VE tables.
It just shows a blank when I look at the histogram tab.
What am I doing wrong, or can someone point me in the right direction to get this set up the way I'm describing?
Thanks in advance.......... :D
