93 flex fuel lumina 3.1 vin w need bin
fmartens6116
Post by fmartens6116 »
i have found a definition file for my data stream but am not sure which bin file to use my car does not have a standard ecu it is only for lumina and i can not find it on the list the ecu in my car is a re-man and it has no ecu number on it atleast that i reconize it list "number: 7-4164 and dc code: 0807TN" when i look up my car i can find "GM Part 16184164 replaced by 88999189" and the other i find is "16184441" but if i remember correctly i saw something that said this one did not fit my car ... but cant find that site again :( any help would greatly be apreciated i would love to use this program and show it off to all my friends :)
you could pull the BIN if you have a PROM burner, otherwise, you're dealing with a VERY rare ECM, i highly doubt anyone has made an XDF for that definition (whatever it is).
however.... if i had to guess, i'd say that it would be VERY similar to A1/DF, just with additions to the algorithm for dealing with the fuel composition sensor(assuming it has one).
