I've been using TunerPro with Dynamic EFI P4 for about 5 months. I am using it on a home built Cadillac 500 in a classic motorhome. I am struggling with the relationship between each of the tables, scalers, and flags.
Is there a manual somewhere that explains each of the Tables, Scalers and Flags, what they do, and their relationship to each other? If so, where can I find/get it?
TIA
Instruction manual for TunerPro?
The XDF file(.bin definition) that you are using in TunerPro is written and provided by Dynamic EFI. They are your best source for an "Instruction Manual" for their XFL file. With the "WhatsUp" display software you should have received the following "Help" documents:
EBL_P4_Calibration.html (this will be the main document you were looking for)
EBL_P4_Information.html (general information about the EBL P$ system)
EBL_P4_WhatsUp.html (WhatsUp display information and instructions)
Other help also available from their website:
http://www.dynamicefi.com/Tune_Intro.php
http://www.dynamicefi.com/Tune_Intro2.php
I really like the products Dynamic EFI provides, but I also wish they would provide all of their documentation in one "User's Manual" instead of having to search through several documents. Hopefully you will eventually remember which information is in which document. You could even rename the document(s) to what makes the most sense to you.
Note: Just a word to the wise - not all of the information in "EBL_P4_Calibration.html" applies to the current XDF file. A small amount of the info is for earlier calibrations. If you get stumped call Dynamic EFI. They do answer the phone.
Carl Rumberger
