Xtronics Romulator chip size emulating bug
JPrevost
Post by JPrevost »
Okay, so I've had my pocket romulator for some time now and it was working GREAT... until I changed it's settings to emulate a larger eprom (from a 2732). So I couldn't find the romulator software on my computer for like 10 minutes of looking so I gave up and thought that TunerPro would work. I open TunerPro and it finds the romulator, awesome, but then it doesn't work. I upload a 4k bin (2732 sized) and plug it into my zifed 8746 ecm. The 1st 4 pins aren't used and just overhang. Well it doesn't work. Turns out you need to set the chip size using xtronics romulator software.
So TunerPro master, I think there needs to be an update :) .
Just read the bin file size and if it's 4k, set the romulator accordingly. Very easy unless you're using a bin stacker and/or flash chip adaptor.
, Jon Prevost from thirdgen.org 91 camaro and still TBI with a mild 350 well into the 13's street trim and daily driven
See my reply at Thirdgen.
