Dash Board display problem?
gwnewlon
Post by gwnewlon »
I am running Tunerpro RT V 4 on my stock 87 Corvette. I am using the Moates Xtreme cable and my laptop is a Dell running Windos XP. The laptop is talking to the ECM and displaying information on the dashboard. My trouble is that the Dash Board momentarily displays properly on the screen then goes to the bottom truncating all of the fields were you can see part of a displayed cell and the rest are not displayed. I am unable to drag it up. Can you tell me what I have messed up.
Gary
gwnewlon
Post by gwnewlon »
Please be advised I have figured it out.
Gary
care to share what the fix is?
i've never heard of or seen this specific issue.
gwnewlon
Post by gwnewlon »
I tried a couple of times to find the part of the window where the mouse cursor changes to a up/down arrow indicating location of resizing of the window. I was then able to pull the window up covering the screen and displaying the cells of default information. I found you can right click on the individual windows and bring up a list of other values. Could you tell me if there are other values and flags that can be added to this drop down list? If so, how do I go about adding more display options to the dash board.
Regards,
Gary
right-clicking should bring up the entire list of values that can be used with the type of gauge selected.
digital and analog should display the same lists, but right-clicking on a status bit will show a different list.
if you want to add more gauges to the dashboard, then you're getting into editting the dash. i have a relatively short tutorial posted about this, read it if you like:
http://tunerpro.net/forum/viewtopic.php?t=2094
gwnewlon
Post by gwnewlon »
Thank You for your help. Is that the discussion on linking?
Gary
