I am using TunerPro version 5.00.7774.00 with ADX file A204 E6 Trans v250 and also A201 E6 v250.
I have a 1993 Chevrolet S-10 Blazer 4.3L Vin W with auto transmission.
Your software works PERFECTLY!! and I had no trouble whatsoever setting it up.
I am not doing any tuning, just data scanning.
I am unable to see an actual, numerical oil pressure reading in any of the data values. This may be because the ECM/PCM does not provide that data for your program to retrieve.
Just curious if you might know if an oil pressure reading is actually available from this PCM. I can give you my VIN if you need it.
Thanks very much for your help,
Jim
Numerical oil pressure reading
- WolfsReign
