Fuel Cutoff Engine Speed, Fuel Resume Engine Speed
x-machinist
Post by x-machinist »
Greetings Fellow Tuners,
I am having a problem with the parameters for Fuel Cutoff Engine Speed and Fuel Resume Engine Speed which I believe are the rev limiter settings. I think there is a problem with the conversion because when using the slider, the numbers in the RPM box jump to values that don't make sense. I have tried tweeking this but can't seem to get it right. Any help with this would be greatly appreciated. Let me know if you need more information.
x-machinist
Here are the specifics.
Car: 1988 Pontiac Fiero GT, 2.8L, 5 speed
AutoProm
Bin: AKYN3442
XDF: 24.xdf
The conversion is correct, but because of the way it is inverted, the slider doesn't work so well.
For now, just type in the values. I've had requests to linearize the slider, but it's not as easy as it sounds. =(
