Hi there,
I'm trying to set up a data acquisition from a BOSCH Motronic 2.10.1 (Porsche 968 CS) via a Moates Ostrich 2.0. TunerPro RT does find the Ostrich on startup (connected via USB) and is able to emulate, but it shows "DA: Not Connected" all the time.
In the "Preferences" window, I set "Interface Type" to "Use Plug-in", "Data Acq. I/O Plug-in Component" to "TunerPro Data Acquisition I/O Interface", "Configure Plug-in Component" to "Port Type: Shared with Emulator". The default baud rate in the ADX file is set to 8192.
Where did I go wrong?
TunerPro RT V5 vs. Moates Ostrich 2.0 - "DA: Not Connec
Best regards ... Bernd
