Tuner Pro RT Items list
zspanners
Post by zspanners »
Hi Guys , anyone got any info on the items list view in TP RT V5.
I am looking at a $12P ADX and tune file.
The items list is one long column down the page , there is plenty of room across the page to display this as 3,4 or 5 columns.
Any one know if this can be done and how??
If you want to view the Monitors and the table is set out at approximately 3/4 screen width then you change to view the Items list you will see what I mean.
Thank you.
zspanners
No, not possible at this time. Lists are a single column (actually, a pair - item name and item value) of items.
zspanners
Post by zspanners »
Magnus , is it possible or coming that we can change this to multiple columns.
Alternatively can we select what items in the list that we want to display , this would make the display list shorter and much easier to view at a glance.
I know that we could write a different ADX list but then you cannot see or select on the fly the data tat you wish to view.
Group the items into different "Item List Views", you can then use the drop down box in the "Item Lists" window to select which group you wish to see.
