Speedomter / Gear Ratio Change
blkblazer
Post by blkblazer »
New to tuning. I have a 93 chevy blazer with 5.7. I recently changed the gears to 4.56. Does anyone know how to modify the speedometer reading for the new gears?
93 Chevy Blazer
Off-Road Direct
Solid Axle Conversion Specialists
http://www.offroaddirect.com
Most masks don't allow you to change speedo calibration in the bin. What mask does your Blazer use?
blkblazer
Post by blkblazer »
I think it is $E6
93 Chevy Blazer
Off-Road Direct
You'll probably have to add the parameters to the XDF. Here they are:
Code: Select all
			* SPEED SENSOR CALIBRATION PARAM'S
			* (2^14 TIME BASE)
     		; LAG FILTER CONSTANTS
L5A0F:	FCB	64 		; 87 msec, RPM filter
L5A10:  FCB	252 	;  6 msec, Input SPD FILTER
L5A11	FCB	252 	;  6 msec, XMISH INPUT SPD FILTER
L5A12:	FCB	1   	; 20 msec MAX PERIOD BETWEEN XISH OUTPUT PULSES
L5A13:	FDB	43691 	; 40 PULSES/REV OUTPUT SHAFT SPD
					; 1092.3 usec/bit
L5A15	FCB	252		; 6 msec, Xmish output spd filt
           	;  GEAR RATIO'S
L5A16:	FDB	44564 	; 2.72:1 4WD LO RATIO
					; VAL = RATIO * 16,384
L5A18&#58;	FCB	45773 	; 44.7&#58;1 NO/VS RATIO  <------------****
					; VAL = RATIO * 1024
L5A1A&#58;	FCB	252 	; 6 msec, Vss filter
blkblazer
Post by blkblazer »
That was fast :lol:
So do I cut and paste the params into the XDF file? Or how do I add the additional info? I hope this isn't a bothersome newbie ?
93 Chevy Blazer
Off-Road Direct
http://tunerpro.net/tutorials/CreatingECUs.htm
The info is a bit outdated (old version of TunerPro), but the takeaways are the same.
