Totally confused!
Kudzu
Totally confused!
Post by Kudzu »
OK, this is the most confusing software I have used. Is there a Tunerpro for Dummies somewhere?? I have read and read and haven't been then lost since I learned CAD.
OK, 16168625 ECM. I have the computer connected and info is flowing. However I am not able to find anything but limited data. Here is a screen shot of what I see.
I want to get all the engine information but I am getting a lot of transmission data. Virtually nothing on the engine.
I am sure that if you understand TP it easy enough to change this. But I have read and read and just PO'ed at this point. After all the reading I still haven't a clue how to use it. All the post I find seem to assume you know something about the basics and I can not find anything explaining TunerPro 101.
that PCM has a couple of datastreams, some of which are basically specific to the transmission, so it was broken up into two sections. you seem to have the transmission ADX loaded.
Kudzu
Post by Kudzu »
OK, I follow you and that makes sense. I know it is great software, way to much bragging on it. But I just need to do some data logging to find a bug and (so far) I just haven't found a really basic tutorial that explains how to start using it.
So, thanks for the input!
Kudzu
Post by Kudzu »
BINGO!!
Thank you very much! Now I have something I can work with.
