MAP and MAF readings on same data log?
iroczinoz
Post by iroczinoz »
Mark I bought this topic up on thirdgen. I can clarify that in datalogging on a 165 ECM there are 2 colums. One with MAF g/sec readings and another MAP volts readings. Is this normal? I also thought that you have one or the other. In ECM852 you don't get 2 readings.
Any ideas?
The MAP item probably shouldn't be there. Are you using the 1227165_6E.ads file from TunerPro? If so, I'll investigate and remove as necessary.
iroczinoz
Post by iroczinoz »
Mangus yes they used the ads file you mentioned. So maybe it just needs to be removed like you say.
