Ostrich 2.0 emulator issue
bran
Post by bran »
Dear All
Sorry for my english
I'm a beginner and i have a OSTRICH 2.0 i want to use for emulation
-i have readed the BIN of my Lancia after
-whit ostrich
-I connect it in the place of the EPROM, with red line on the top of the soket
-Ostrich setup 28pin
-i use Tuner pro
-I load the BIN of the eprom
-i upload the bin on the ostrich successfully
-and after i try to emulate
- i have this on the bar
https://drive.google.com/open?id=0B_OR4 ... authuser=0
[Emulating] [Hardware: Ostrich 20.9.0] [Ready]...
But the car don't run
I tryed also the EmuUtility
Whit the same original BIN file
and the result is the same
I miss some step?
what i can check?
Thanks in advance
Some eeproms (for example the 27C32) require the use of the Moates SocketBooster for emulation to work.
bran
Post by bran »
I'm using a 27C128
i think it don't need
bran
first problem found
Post by bran »
I have found the first problem
was the configuration of the EmuUtility
as the picture show the problem was the END JUSTIFY flag
begause of the dimension of my file it was stored at the end of the Ostrich memory.
Now loading the file with EmuUtility my car run perfectly
bran
New issue loading file First 2 byte different
Post by bran »
As you can see in the previous post
my ostrich 2.0 uploading the file using EmuUtility work well.
But...
Uploading the file in ostrich using tunerproRT i have the following problem.
The first 2 byte of the file are different .
if i read the ostrich using an eprom programmer i see that
the first 2 byte are different from the original and the car does not run
Thanks for help
Are you using an xdf that has a checksum calculation in it? This could be changing the first two bytes in your bin file.
bran
Post by bran »
On the checksum configuration i have
Data Start 0000
Data End 3FFF
Store Address 3D10...
