Hello @ all,
I'm new here and I think I'm right. in advance I have to apologize for my bad English (from Germany).
I had times ne question and although I have a G60 ECU I Batronix with tuner-pro / / ostrich 2.0 editing. works so far really great !!! I got to the set the problem with the idle fuel that is combined with the startup enrichment? i`m working with 1ignition map.
am really fit with the mechanic and electrician, the software I feel my first zoom ...
I thank you in advance for reply or aids.
Gruss Benny
G60 ECU
first try to use a map with the 3 ignition tables, tey are much better.
which kind of digifant do you use?
DP? or the old A?
the start up enrichment has influence to every thing of the ecu, from idle to boost.
ok, mal auf deutsch
die neuen 3 map sind deutlich ausgefeilter. nimm die lieber
die startanreicherungs map und die kaltlaufmap haben einfluß auf alles; von leerlauf über beschleunigungsanreicherung bis vollast; sogar schon im serienzustand.
oder was meinst du?
DP? or the old A?
ok, mal auf deutsch
oder was meinst du?
