eprom problem please help
zlp
Post by zlp »
I am using TunerPRO RT on a 90s camaro. my problem is that when I have RT hooked up and am emulating/ making changes on the fly the engine responds, but when I save and close RT Remove the chip and put it in the ecm. IT acts compleetly diffrent that when I had it hooked up and tuning on the fly. Does any one know what the issue is ?
Does the chip you are programming have more memory than the ecu's stock chip? If so, are you offsetting the bin file when programming the chip?
damanx
Post by damanx »
Can you provide some details about what you are using with TunerPro during your "emulation"?
This is a guess, but do you change the "code mask" to AAh in TunerPro before uploading the BIN to the emulator?
I just started using the Ostrich2 and failed to do that and saw weird stuff.
