I have a couple general questions that are probably no brainers for most of you. I tried searching but probably did not use the correct key words.
I have a Syclone we are going to be tuning. Guy does not what size injectors are in it, nor the brand of turbo kit.
I've downloaded the bin file xdf and the log file from Moates. I have Ostrich 2.0, Xtreme ALDL.
My questions are:
1) Can I pull the tune from the ecu or is it on the chip? This would save me time if I can get injector data from the ecu. Be NICE! I said I was a newb.
2) Is there a link or how to for general usage on using the hardware? I'm not scared of the software or tuning, but this is all out of my wheelhouse when it comes to burning chips, installing adapters etc. I have the ecu out and see where it plugs into. Previous person cut an access hole in the ecu cover.
3) If not for #2, how do I know which was to flip the switches on the OStrich and ALDL?
The truck is a 91 syclone so I'm assuming the ECU is 1227749.
Thanks in advance.
Newb Help
http://www.gearhead-efi.com/Fuel-Inject ... rmation-58
If you havent already< check out this thread at Gearhead-EFI . Good group of guys and if they don't have the answers you seek they can surely direct you to someone/somewhere that can.
Buddrow
Buddrow
