My tuner has requested these values: MINIMUM, FUEL, IDLE AIR, and MAFV.
I've scoured the Parameter list in Tuner Pro RT but I can't find anything that looks anything like any of the four of those.
I have a custom BIN loaded, the GUFB.xdf XDF file and the GUFB_56k.adx file loaded.
I've also connected the 0-5V output of the AFR meter to pin 27 of my EEC-IV, should be the ecu's EGR valve position input. I imagine this is to log the AFR which gets delivered to the ecu as the EGR position, but I can't find anything that looks like that either in the Parameters list.
I'm following the instructions here: http://tunerpro.net/forum/viewtopic.php?t=2674
Thanks for any ideas which values to log.
Can't find requested numbers to log
Ophitoxaemia
