Why Tunerpro v5 doesn't read the correct addresses?
deltaza
Post by deltaza »
Hello
I'm trying to understand why with a bin with addresses from 0 to 8000, Tunerpro reads only if you put....addresses STARTING from 8000
I mean, Tunerpro read not values at 0DD0 (for example) where the value IS, but only if you put the address as 8DD0.
For example...that address is the "turbo duty cycle" 4x16 table.
If you put the correct address of 0DD0, the program reads 00 for all the values.
You have to put the address as 8DD0 to make the program reading.
Try this xdf: http://www.tunerpro.net/download/bindef ... 6VT_KJ.xdf
And this bin: http://www.berlinasportivo.com/Technica ... 021601.BIN
Other problem: emulating on the road, with Ostrich, in that table the yellow box doesn't light correct values and moves in a apparently random way
See the "Base offset" field in the XDF header (Ctrl + F2)
deltaza
Post by deltaza »
Mangus wrote:See the "Base offset" field in the XDF header (Ctrl + F2)
AH! Thank you very much...so it isn't a bug...sorry! :oops:
Why did, who make that xdf, translate the addresses after 8000?
I don't understand the utility.
But could it cause also the random reading on the road? :?
I mean that the yellow box, during emulation, doesn't go in the right places...
