i was looking through a DF documentation and im wondering
maybe i am able to add the the df.xdf i have
but now i have come to a halt
say i want to add a table...
spark retard time during shift
(from the document)
Code: Select all
# F119STM #
# STALL TORQUE MANAGEMENT SPARK ADVANCE VS. RPM AND MAP #
# N=E*256/90 #
0793 30 48 F119STM 48 R MIN; R = NTRPMX
0794 90 144 144 Q MIN; Q = NMAPLD
0795 08 8 8 R NUM
* --------------------------------------------- SPEED 1200 RPM
0796 47 71 25 DEG 65 KPA-MAP
0797 47 71 25 DEG 70
0798 47 71 25 DEG 75
0799 47 71 25 DEG 80
079A 47 71 25 DEG 85
079B 47 71 25 DEG 90
079C 47 71 25 DEG 95
079D 47 71 25 DEG 100
* --------------------------------------------- SPEED 1600 RPM
079E 47 71 25 DEG 65 KPA-MAP
079F 47 71 25 DEG 70
07A0 47 71 25 DEG 75
07A1 47 71 25 DEG 80
07A2 47 71 25 DEG 85
07A3 47 71 25 DEG 90
07A4 2B 43 15 DEG 95
07A5 00 0 0 DEG 100
* --------------------------------------------- SPEED 2000 RPM
07A6 47 71 25 DEG 65 KPA-MAP
07A7 47 71 25 DEG 70
07A8 47 71 25 DEG 75
07A9 47 71 25 DEG 80
07AA 47 71 25 DEG 85
07AB 47 71 25 DEG 90
07AC 22 34 12 DEG 95
07AD 00 0 0 DEG 100
* --------------------------------------------- SPEED 2400 RPM
07AE 47 71 25 DEG 65 KPA-MAP
07AF 47 71 25 DEG 70
07B0 47 71 25 DEG 75
07B1 47 71 25 DEG 80
07B2 47 71 25 DEG 85
07B3 47 71 25 DEG 90
07B4 1C 28 10 DEG 95
07B5 00 0 0 DEG 100
* --------------------------------------------- SPEED 2800 RPM
07B6 47 71 25 DEG 65 KPA-MAP
07B7 47 71 25 DEG 70
07B8 47 71 25 DEG 75
07B9 47 71 25 DEG 80
07BA 47 71 25 DEG 85
07BB 47 71 25 DEG 90
07BC 1C 28 10 DEG 95
07BD 00 0 0 DEG 100
* --------------------------------------------- SPEED 3200 RPM
07BE 47 71 25 DEG 65 KPA-MAP
07BF 47 71 25 DEG 70
07C0 47 71 25 DEG 75
07C1 47 71 25 DEG 80
07C2 47 71 25 DEG 85
07C3 47 71 25 DEG 90
07C4 19 25 8.8 DEG 95
07C5 00 0 0 DEG 100
* --------------------------------------------- SPEED 3600 RPM
07C6 47 71 25 DEG 65 KPA-MAP
07C7 47 71 25 DEG 70
07C8 47 71 25 DEG 75
07C9 47 71 25 DEG 80
07CA 47 71 25 DEG 85
07CB 47 71 25 DEG 90
07CC 17 23 8 DEG 95
07CD 00 0 0 DEG 100
* --------------------------------------------- SPEED 4000 RPM
07CE 47 71 25 DEG 65 KPA-MAP
07CF 47 71 25 DEG 70
07D0 47 71 25 DEG 75
07D1 47 71 25 DEG 80
07D2 47 71 25 DEG 85
07D3 47 71 25 DEG 90
07D4 47 71 25 DEG 95
07D5 47 71 25 DEG 100
* --------------------------------------------- SPEED 4400 RPM
07D6 47 71 25 DEG 65 KPA-MAP
07D7 47 71 25 DEG 70
07D8 47 71 25 DEG 75
07D9 47 71 25 DEG 80
07DA 47 71 25 DEG 85
07DB 47 71 25 DEG 90
07DC 47 71 25 DEG 95
07DD 47 71 25 DEG 100
07DE E4 228 KRPM12 5700 RPM RPM THRESH FOR SPARK RETARD DURING 1-2 SHIFT
07DF B3 179 KTPS12 70 % TPS THRESH FOR SPARK RETARD DURING 1-2 SHIFT
07E0 E4 228 KRPM23 5700 RPM RPM THRESH FOR SPARK RETARD DURING 2-3 SHIFT
07E1 B3 179 KTPS23 70 % TPS THRESH FOR SPARK RETARD DURING 2-3 SHIFT
* F12DELTA TABLE: NEGATIVE RPM DELTA ENABLE #
* THRESHOLD FOR SHIFT ENERGY #
* SPARK RETARD, 1-2 UPSHIFT #
* VS. RPM #
* TABLE VALUE = RPM DELTA #
07E2 25 37 F12DELTA 37 RPM 2800 RPM-SPEED
07E3 25 37 37 RPM 3200
07E4 25 37 37 RPM 3600
07E5 25 37 37 RPM 4000
07E6 25 37 37 RPM 4400
07E7 25 37 37 RPM 4800
07E8 25 37 37 RPM 5200
07E9 25 37 37 RPM 5600
07EA 25 37 37 RPM 6000
07EB 25 37 37 RPM 6400
* F12DELTB TABLE: NEGATIVE RPM DELTA EXIT #
* VS. RPM #
07EC 55 85 F12DELTB 85 RPM 2800 RPM-SPEED
07ED 55 85 85 RPM 3200
07EE 55 85 85 RPM 3600
07EF 45 69 69 RPM 4000
07F0 40 64 64 RPM 4400
07F1 35 53 53 RPM 4800
07F2 26 38 38 RPM 5200
07F3 26 38 38 RPM 5600
07F4 26 38 38 RPM 6000
07F5 26 38 38 RPM 6400
* F1TIME12 TABLE: PRETIMER THRESHOLD BEFORE #
* ALLOWING SHIFT ENERGY #
* VS. RPM #
* TABLE VALUE = SEC * 80 #
07F6 04 4 F1TIME12 0.05 SEC 2800 RPM-SPEED
07F7 04 4 0.05 SEC 3200
07F8 04 4 0.05 SEC 3600
07F9 04 4 0.05 SEC 4000
07FA 04 4 0.05 SEC 4400
07FB 04 4 0.05 SEC 4800
07FC 04 4 0.05 SEC 5200
07FD 03 3 0.04 SEC 5600
07FE 02 2 0.02 SEC 6000
07FF 01 1 0.01 SEC 6400
* F2TIME12 TABLE: SHIFT ENERGY SPARK RETARD #
* TIME DURING 1-2 UPSHIFT #
* VS. RPM #
0800 01 1 F2TIME12 0.01 SEC 2800 RPM-SPEED
0801 02 2 0.02 SEC 3200
0802 03 3 0.04 SEC 3600
0803 04 4 0.05 SEC 4000
0804 05 5 0.06 SEC 4400
0805 10 16 0.2 SEC 4800
0806 10 16 0.2 SEC 5200
0807 10 16 0.2 SEC 5600
0808 10 16 0.2 SEC 6000
0809 10 16 0.2 SEC 6400
so for example i would go into df.xdf and create a table
%%TABLE%%
000002 UniqueID =0x40D4 Creating a unique id use hex address as id?
040005 Title =" the title "
040011 DescSize =0x0 allways the same?
040010 Desc ="" description? notes ?
040100 Address =0x91E hex address ?
040200 ZEq =(1.000000 * X) + 0.000000,TH|0|0|0|0| ??????
040230 RangeLow =0.0000 allways the same ??
040240 RangeHigh =255.0000 allways the same ??
040300 Rows =0x11 verticle rows?
040305 Cols =0x1 horizontal rows ?
040320 XUnits ="" ???????
040325 YUnits ="" ???????
040330 ZUnits ="" ???????
040350 XLabels ="" ???????
040352 XLabelType =0x4 ???????
040354 XEq =X,TH|0|0|0|0| ???????
040360 YLabels = "" ???????
040362 YLabelType =0x4 ???????
040364 YEq =X,TH|0|0|0|0| ???????
040660 XAxisMin =0.000000 allways the same ???
040670 XAxisMax =1000.000000 allways the same ???
040760 YAxisMin =0.000000 allways the same ???
040770 YAxisMax =1000.000000 allways the same ???
%%END%%
so im just not sure about everything in red, and how the calculations are derived, im guessing its not documented in the df.doc ?
i think the df.xdf needs an update as its missing alot of usefull features
this is very technical but i think if i can find out where to look (hex a bin file?) to get the information, and what tunerpro needs in the xdf and how they function i might be able to go on my mery way and make a complete mapping of the df.xdf file
