help please! :( dme 413 turbo
I have 525 m50 turbo, I,m going to adjust 413 ecu on my engine. But I can't understan on the ignition map, during the increase meanings when happens spark? Early or late? I need your help very much, I have to place my car on dyno tomorrow. So looking forward for your answer. Thanks beforehand
help
I'm interested in early and late spark on the ignition map during the increase numbers. If it is early or late/tardy?
mohamedramli wrote:If you look at the PT ignition table, as the RPM is higher, the number in the cell is higher. Meaning the bigger the number the bigger the ignition advance.
thank you very much )))))) today I will regulate my ecu and upload link of the dyno video let"s see how much WHP will be, the engine is m50b25 turbo pressure 12psi boosted))))
