Searching for XDF 0261200172 and 0261204620
Lambda1
Post by Lambda1 »
Hi,
searching for a while ...
M20B20 / M20B25 0261200172 xdf file and also xdf for
Bosch ME7.2 0261204620.
If someone can help, please.
Lambda1
Post by Lambda1 »
Im willing to pay for it ;)
Hairyscreech
Post by Hairyscreech »
172 and 173 hardware is the same as far as I am aware, you can use the same chip in either ECU to run either of the corresponding engines.
I have a standard 172 ECU sitting in my office that I could pull the .bin off for you to compare with the 173 .bin.
If the files are the same bar the values in the maps, then why not just tune using the 173 .bin or use the 173 XDF?
A similar situation to the M3.3.1 413 and 506 ECU on the E36.
Lambda1
Post by Lambda1 »
You cant use 172er bin with xdf for 173 ...
Maybe (i dont tested) you can use 173er bin in 172er ecu.
I search for 172 xdf.
Hairyscreech
If you are really set on using the 172 bin then your best off making the XDF yourself.
All the maps you need are laid out on the 173 XDF and the corresponding data in the 172 bin will not be too far from the 173 location (simply due to how BMW did the code).
aboutton
Post by aboutton »
use 173 bin with 173 xdf in 172 DME
both ECU are identical
HyperBoost Tuning
Tony Ouneissy
Lebanon
Lambda1
Post by Lambda1 »
I know this facts ... and I do.
First Time I want to use 172er but it seems nobody have xdf ... so i will create by my one if i had time for it.
But for 0261204620 maybe someone have once?
