QH mode and tune position?
timhodge
Post by timhodge »
My laptop crashed and I no longer have access to BE so looking at registering with TPRT. I feel I'm missing something but there seems to be no access to set QH mode and tune position. Also no way to dl ford tune from ecm. Seems weird no one has run across this before. Probably just me but
can anyone explain?
Tim
timhodge
Re: QH mode and tune position?
Post by timhodge »
It's 4 years later and I have the same question. Weird, huh? Maybe someone could tell me if there's a way to access these functions with the TunerPro. I would really appreciate it. If there's not, will it work anyway?
wwhite
Post by wwhite »
You need the corresponding XDF file for your PCM/tune bin file.
decipha
Post by decipha »
You cannot change the mode as tunerpro configures it for mode 4 tune 2. As long as the QH isn't set to disabled mode 0 then tunerpro will correctly configure it.
You download tune from the ecu with the qh the same way you read a chip.
details- http://www.efidyntuning.com/started.htm
