Adress Hit Tracing: counting readed cells?
AK16
Post by AK16 »
is it possible to count the used cells while TunerPRO/ostrich is in hit tracing mode?
I have a video, look at the link.
This is a trace of my address table.
I cant get any informatioen out of the trace.
If TunerPro would count the hits, the trace may be usefull?
This feature maybe change the cells with many reads in to dark color? So we can create a big table an watch a big area the see, whitch bytes are often read?
https://youtu.be/EkqiLpHhrNY
Acki
Re: Adress Hit Tracing: counting readed cells?
Post by Acki »
It's look like datacode you are tracing - for the tables it's useful to see if this table is read or not.
AK16
Post by AK16 »
no, this is the map table. You can see the increasing byte.
The feature allready exits:
https://youtu.be/4cbeXHrYra0
Toos->Hardware Utilities->Address Watch Utility
Duckmang
Post by Duckmang »
My German is more than a bit rusty. Any other sources on how to use this feature? I just get a blank screen that even with trace parameters defined, doesn't appear to do anything.
I've got a 16x16 block of code that contains most of the constants and it would be awesome to get a hit count on it.
AK16
Post by AK16 »
look at the end of the video. English.
