075 DME XDF help?
Omniscient
075 DME XDF help?
Post by Omniscient »
Hello, I pulled the chip from my 1994 E36 M3. I'm currently working on a XDF for it so I can extend the MAF fault table and remove the sensor. Can anyone give me some input on what these identified maps might be? Image
Duckmang
Re: 075 DME XDF help?
Post by Duckmang »
The table at 7750 that is full of the value 128, I'd suspect it could be a low load lambda table. I have a similarly populated table in my wholly unrelated but still Bosch xdf. Values higher than 128 would be richer and below 128 leaner. If you have a wideband and / or an emulator it would be fairly easy to test.
