map
papaford
map
Post by papaford »
absolutely fantastic... love your program..
not registered yet but I definately will.
I have a question about map sensor data in the 8d code.
Your program is giving data in voltage instead of atmospheric
pressure... is there a way for me to change or convert this?
Thanks, Dana
If you're talking about the ECU, yes, its as simple as modifying the ECU Item in question with the correct factor/offset to convert the voltage to BAR (or whatever).
If you're talkinga bout the ALDL 730 datastream definition, yeah, I'll take care of this for you. You're the second person to ask for it. =)
In a future version (near future) you will have a datastream definition editor, so you can modify this stuff yourself.
The next release will have the 730 datastream with MAP in bars instead of volts.
papaford
Post by papaford »
great. thanks for the reply.. another question..
do you have an appoximate time frame as to when your
update will include data logging?
next release. i've got it working nicely so far. =)
