Changing table values using + / - keys does not register a change
tightmopedman9
Post by tightmopedman9 »
Using the newest version (5.00.9513.00)
When a table's values are changed using either the + or - key, the change is not registered as modification, and therefore the modified values are not saved when 'save' is clicked. If the + or - key is used to modify table values and then one (or more) of the values is changed manually or using the function/execute button, all updated values will register and will be saved.
Re: Changing table values using + / - keys does not register a change
This seems to be working in the latest build.
